Seagate’s new Mach.2 is the world’s fastest conventional hard drive
Started by neurosis, May 22, 2021, 08:44 AM
They are claiming that this drive will be able to compete with some ssd speeds.  Looks interesting.
https://arstechnica.com/gadgets/2021/05/seagates-new-mach-2-is-the-worlds-fastest-conventional-hard-drive/">https://arstechnica.com/gadgets/2021/05 ... ard-drive/">https://arstechnica.com/gadgets/2021/05/seagates-new-mach-2-is-the-worlds-fastest-conventional-hard-drive/
QuoteSeagate lists the sustained, sequential transfer rate of the Mach.2 as up to 524MBps—easily double that of a fast "normal" rust disk and edging into SATA SSD territory. The performance gains extend into random I/O territory as well, with 304 IOPS read / 384 IOPS write and only 4.16 ms average latency. (Normal hard drives tend to be 100/150 IOPS and about the same average latency.)
Should be great for datacenters.
...only 20 years late, just like GM/ford/toyota and the internal combustion engine
in the 90s i worked at a place making reader-head lapping machines, selling them to Seagate and others. Pretty High Tech at the time. Will info on a HDD survive an EMP? Otherwise, what's the point?
